You do not have to retest UNLESS you do not file so many permits in a certain period , You must do that to keep your License Active. Also Chicago at this time does not required update Schooling as several other states do. If you Plan to take the Chicago test Make sure you get a current in force copy of the Chicago Code. Yoopers
