Originally posted by sparky66wv:
[b]Here in my area we use Romex connectors for split-bolts too
Maybe I'm just a goody-two-shoes, but I cannot consider the use of NM Connectors for split bolts in any way kosher or acceptable. I've seen too many connections that were installed with approved means fail...
[/B]
I assume using rx connectors to splice in a service is only done in a locality where the utility follows through and makes proper connections. You should check when working in a new region, because our utility does not re-do services taps.
