Randy, grounding, as in "grounding", is simply for bonding reference and bracing of the system (in this case a MGN system) in high voltage surges. The earth, unless specifically used for a "return to source" conductor, (SWER) would never be considered a circuit path, or in the HGTV meaning, it certainly wouldn't be part of the "source".
