HotLine, those are interesting requirements; are they ever enforced?
I did a service recently, where I mounted the pan on strut specifically so I could get the lags into studs, and not just siding. In most circumstances, I don't know how you could locate the studs, under the sheathing and the siding. In my case, the inside wall was opened up. Even so, I used only 1/4" lag bolts.
Other trade forums have expressed very strong, negative opinions regarding strut on houses; it is felt to be ugly.
For our kiosk, I don't see where you could place two straps - unless it was acceptable to place them right next to each other.
Just for the sake of illustration, here's a picture of a mast with guy wire support. A commercially prepared 'kit' was used, and that cable is a lot smaller than 1/4":
![[Linked Image from i143.photobucket.com]](https://i143.photobucket.com/albums/r138/renosteinke/Electrical%20Foibles/Mastguylines.jpg)
