Originally Posted by gfretwell
Ever the scientist I just tried acetone on some cured spray can foam. (Great Stuff, controlled expansion in the blue can)
It softened it up a little but it did not get gummy or break down in a 5 minute soak. It might help you get it out of your clothes tho but if you have "plastic" clothes it might eat a hole in them.
Trichlorethane 1.1.1 is similar.
Lacquer thinner was even less effective.
This is polyurethane and there is not much that will eat it.
Dynasolve CU-6 says they can do it but this is pretty nasty stuff.
http://www.customlinings.com/industrial/ApplicatorsOnly/MSDS_Sheets/CU6_MSDS_SHEET.pdf
I accidently tried acetone on a nylon windshirt, (Was going to use lacquer thinner on a stain)It did no harm it may have no harmful effect on other plastics....
On the orig. topic, learned the hard way about sealing conduits when came back to fixtures full of water. Lesson learned.
