I am not sure there are any NEC rules about required receptacles in the common areas beyond what you need to service equipment and appliances. (210.50(C) & 210.63)
There are lighting outlet requirements in the life safety code for the egress routes.
You may also have more guidance in the building code. I know Florida has adopted the NEC unaltered state wide but when they want something beyond the NEC (like bonding steel studs) they put it in the building code.
