120V 400Hz. I wonder what would happen if some pushy first-class executive decided to plug his laptop in there?
Actually I'd expect it to work ok as the supply is fed straight into a bridge rectifier. The switchmode power supply runs off DC (AC mains RMS x 1.4142). The only limitation would be the switching speed of the diodes but that would only become significant well into the KHz region.
