Hi all
I would like tap on the huge knowledge base here to clarify my query.
Basically I am in Singapore which provides power at 230V50Hz. I would like to import a ceiling fan from the USA which is set for 110V60hz.
I know I am able to use a transformer to convert the 110V to 230V, however there seems to be no way to convert 50hz to 60Hz.
My question is whether using the fan on 230V50Hz(using a transformer) would negatively impact the fan.
-Would the motor burn out? Shorten the motor life?
-Alot of extra heat generated?
Thank you all in advance for any advise you have.
Cheers
