mem_singleoutlet - socket outlet. The white cable from the lower right is a more recent hack-job, this goes to another surface mounted socket outlet nearby. Most of the others in the property have been extended in this way:
cooker_control_mk - older type control for an electric cooker. Metal face with a plastic insert. This works, but the whole assembly is now loose from the wall and the insert is loose also:
rose_closed, rose_open - older type lighting rose, ceiling mounted. This one is on a sloping ceiling hence the odd angle of the flex. The drop-wires are modern, everything else is not:
rose_wires - closeup of the interior of the lighting rose. Although terminals are provided for switch and loop wires, these are not used; there must be other junction boxes elsewhere in the ceiling void:
sadia_heater - electric wall mounted water boiler. Kitchen sink immediately below.
There is a larger model of this heater elsewhere in the property which supplies hot water to the bathroom:
![[Linked Image]](https://www.electrical-contractor.net/Nostalgia/UK/sadia_heater.jpg)
