In Ireland at the moment the vast majority of sets on sale are either 12 or 24V with a plug in transformer. They're wired in series but with a by-pass so the bulb going won't take out the whole set.
The irritating flashing type strings have multiple circuits to allow them to chase etc
The older sets were the same as paul described. Usually dark green or semi-seethru green twisted pair cabling. And yes we do use the BS1363 plugs on them.
I have even seen a set wired to a 15A BS546 plug!! It does look comical.
Some sets also arrive with "Europlug" 2-pin flat plugs which are quite often just jammed into a 4-way BS1363 power strip under the tree.. or as I've also observed into 4 shaver adaptors on a powerstrip.. meaning they were all fused at 1A ! Seemed to work fine though and actually can't see a huge problem with that arrangement.
Outdoors CEE-17 is required and in anything which is within reach of people safety extra low voltage is now compulsary.
http://www.noma.co.uk/christmas/faq/christmaslightingsets.htm explains everything about xmas lights
[This message has been edited by djk (edited 12-10-2003).]
