THAT receptacle will look funny to those with good eyes. That is because this receptacle has a standard 120 pattern on the botton, and a 220 v. pattern above.
Those combo receptacles are still available.
But I would not suggest using it like this.
The 120 part, where active (not every room is) is powered from one leg of the heater circuit, and uses the conduit as a "neutral."
Bob Badger Construction & Maintenance Electrician Massachusetts
