So did you actually start the work or is this a report on what you believe needs to be done. Is it possible to walk away at this point. That is what I would do. You have done the right thing without question, you can only make people do what they want to do I guess. File the report with the appropriate authority(s) and leave it it that. You can then move on knowing you did your best to right a wrong. These are CLEAR violations to anyone with any knowledge of the NEC. This would not fly here in Mass. This guy would be before the Board of Electricians for sure.
[This message has been edited by Electricmanscott (edited 07-12-2002).]
