Most people fail to read the fine print on their inspection report. Most reports always have the clause "recommend inspection by a qualified electrician, plumber, hvac company etc etc. The inspection merely passes the responsibility on therfore limiting the inspectors liability. I recently was called to fix some problems on a residential panel. The inspector noted two minor problems but he never mentioned the single hot conductor landed on a 20 amp breaker going to the garage all by itself then picking up a convienent neutral in the garage to complete the circuit nor did he mention the fact that the panel was an FPE. Now I have to look like a crook telling them I can't put our name on it unless we fix everything.
