0 members (), 555 guests, and 17 robots.
gserve Offline OP
I need to splice a 2 wire #18 thermostat wire. Does this spice need to be accessible? This is in a garage that is going to have a fire rated ceiling installed over the splice.
Workgear for Electricians
Ron Offline
Although the code doesn't require the splice to be in a box or remain accessible, it is a darn good idea.
Ron
As Ron said...
the 'Code' of common sense' should prevail, and the splice should be accessable.
Think about if you may have to return!!!
A nail on box and a blank cover ($ 1.50)
would be worth it
ken
