0 members (), 934 guests, and 13 robots.
pwregan Offline OP
need to figure a feeder size for a 4 unit condo building,4- 100 amp panels for condos, and 1- 60 amp panel for house panel
any help will be greatly appreciated
thank you,
pwregan
Workgear for Electricians
As this is a somewhat code-related issue, I'm going to move this across to the NEC area for better coverage.
Bob Offline
Look at 220.31 and 220.32 for the caculations and adjustments in the 2002 code
[This message has been edited by Bob (edited 07-27-2005).]
See the 2005 NEC in Annex D for Examples that will help you make the calculations.
Um, 220.31?? My book ('05 handbook) skips from 220.18 to 220.40...
I didn't think that was such a dumb question.
