Electricians revenge
0 members (), 188 guests, and 17 robots.
#9229 04/24/02 12:21 AM
Anyone ever MEG one of these things to see how they compare to a wirenut?
A few years ago, I had a service call for a recessed canister light that had quit working. It was a bear to get to as well, and one of these connectors was the problem.
I'm stuck in my ways though...
-Virgil
5 Star Inspections
Member IAEI
#9230 04/26/02 12:04 AM
CRW Offline
We just used thousands of the Ideal brand connectors on 277V fluorescents, changing out ballasts. The office building spec'd them and they were very quick and easy to use. They've been using them for awhile now, and I don't think there have been problems yet.
#9231 04/28/02 02:31 PM
Tester: AVO Megger BM21
Item:Ideal Wing Nut #30-452 Red
Voltage:1024VDC @ 1 min
Insulation value:374G ohms
Item:Wago 773-106 Push Connector
Voltage: 1025VDC @ 1 min
Insulation value:427G ohms
Alltests are measured from internal wire connection point to external of insulation cap.
in the next day or so I'll publish restance values across two wires in the connector
Stay Tuned...
Mike Wescoatt
