ShoutChat Box
Split Bus Breaker Panel
by grich - 01/27/21 04:57 PM
electircal ageing test on IPC
by quickspark - 01/27/21 08:22 AM
What Does a Ground Rod Do?
by quickspark - 01/26/21 12:38 AM
Floating Ground - device being tested or scope?
by quickspark - 01/26/21 12:36 AM
Ground fault remover :-)
by dsk - 01/24/21 04:35 AM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 19 guests, and 16 spiders.
Wall sconce lights over hydromassage tub... #87085 01/20/04 10:17 AM
4
4 Bears Offline OP
I have read lots on this subject but want to get some of your ideas on this issue. My brother wants to install wall sconce lights (2 of them) on the back side of the hydro tub wall. They will be 7'-6" off of the floor and 6'-0" from the max. water surface fill height. What would some of you do in this situation? Would you do it? Would you put them on gfci? With the lights being so high, do they need to still be wet location lights? The bathroom has vaulted ceilings that are 10'-0". Any ideas?
2017 / 2014 NEC & Related Books and Study Guides
Re: Wall sconce lights over hydromassage tub... #87086 01/20/04 11:38 AM
russ m Offline
Check this out.
Many times you can search a for a subject.
Hit search, the NEC, and type in wall sconce.
https://www.electrical-contractor.net/ubb/Forum2/HTML/001285.html
Re: Wall sconce lights over hydromassage tub... #87087 01/20/04 12:04 PM
4
4 Bears Offline OP
I have read that several times . I was just wondering what some of your ideas and thoughts were on this.
Re: Wall sconce lights over hydromassage tub... #87088 01/20/04 12:34 PM
russ m Offline
I'd put it on a GFCI at the very least.
I think the code should be reworded, so the lights are not on a wall the tub enclosure touches,or is so close to the tub you have to stand in or on the tub or enclosure to change the lamp.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
renosteinke
renosteinke
Blue Collar Country
Show All Member Profiles
Trumpy 18
NORCAL 10
274,318 Are you busy
208,165 Re: Forum
195,753 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
