#82648 12/05/02 12:52 PM
ayrton Offline OP
In my Int Fire Code book they list what kind of fire systems are required per what kind of "Group" the building is. Where can I find the definitions for the different groups?
Ex Group A, Group E, Group R1 etc.
#82649 12/05/02 02:42 PM
It sounds like you would have to try the NFPA (National Fire Protection Association). However the information is not free. It will cost you, or you could call up an architect. Or a fire sprinkler contrator.
Scott
#82650 12/05/02 08:50 PM
Ron Offline
Which int fire code book are you using? The international building code has definitions as to group types for buildings in the book.
Ron
#82651 12/05/02 09:30 PM
You should be able to get the info you need from the building dept., or building inspector in your locality, or state. Also, the Fire Marshal (Fire Inspector) should be able to answer you.
#82652 12/06/02 08:47 AM
ayrton Offline OP
It is the 2000 International Fire Code. Big red book. If I would have looked in the front, under definitions I would have found it. Sorry to bother you
#82653 12/07/02 05:35 PM
When all else fails...Read the instructions.
Scott
#82654 12/07/02 11:27 PM
Check with your local BOCA chapter for the exact listings, however a brief description is: A= Assembly (5 different classes)
B+ business..........E=Educational.....
F=Factory (2 classes).....H=High Hazard....I=Instituional(3 classes)....M=Merchantile....R=Residential(3 classes)....S=Storage (2 classes) and U=Utility. If you want more info, I will get it for you.
Harold
#82655 12/07/02 11:30 PM
That previous post was suppose to say B=Business. Also by different classes A-1 is theater, A-2 is night club, A-3 is restaurant, A-4 is church, and A-5 is outdoor assembly. R-1 is Hotel, R-2 is multi family and R-3 is one/two family dwellings.
Harold
