0 members (), 449 guests, and 10 robots.
John ---
You are correct that some juristictians have "requirements" for inspections at the time of sale.
I hope those inspections for a transfer of ownership not change of use are simply to insure that no unpermitted work was done and to recommend not order that work (like adding CFGI's or smoke detectors) be done.
In any case you negotiate with the seller, and who pays and what is done is resolved in the final paperwork.
Workgear for Electricians
Almost all of the home inspectors here are hired by the real estate companies. Typically a FHA/VA loan requires this inspection. Most of these inspector around here took a short course and now know everything just ask them. Many of them condem two wire outlets in 35+ year old homes, always want GFCI within 6' of water, want sump pump single outlets changed to GFCI, demand conduit in unfinished basements drilled thru the studs or floor joists, and always will condem a fuse panel.
I have yet to meet any one of them who ever built a house in any trade.
But since the bankers rely on them, upgrading if not too costly is worth while.
Have any work done by a licensed contractor, some times the contractor can give you a statement of his inspection and repairs (if any) on your place. If some work is not required by local code he can supply the reference.
I just wish we could get some licensing requirements with actual work experience on these so-called inspectors.
Gool luck in the sale of your place.
ed
If you decide to install the gfci`s you may want to change the breaker feeding the circuits now with a gfci breaker .Yes this will cost a little more but if the breaker that now exist cuts off all the outlets you`d be asured to have it all protected.This would be better for kitchen depends on the layout of circuits.In garage maybe change to gfci rec. Most of the time here in NC we`ll do these things for the realty company as the loan provider is protecting their investment as well...
George:
The "inspections" are visual, and we primarily look for life/safety items. Recently found a garage door opener that was wired with "zip cord" that had sta-kons onto the cord cap on the opener; the "zip cord" was tapped off of one leg of the 30 amp dryer outlet, fed a receptacle in a handi-box, and was free air spliced. All of this was secured by 1 staple and some duct tape.
The building dept looks for un-permitted work that was done in the past. The Fire Official checks for smoke detectors. The GFI situation is "suggested", not mandatory.
PS: I do electrical inspections for the Twp, I'm not a House Inspector.
nesparky,
There are several home inspectors in my area who have built more than a few houses. I oeversaw the building of my own home and have done quite a bit of electrical on new and old homes (I'm an electrician and home inspector).
A home inspector should never cite code unless he is certified as a code official.
Yes, all of the states need to require laws that insure a home inspector knows what he is doing. The problem is that (there are currently 25 states that require experience and/or training)many of the states that have passed laws, have put the home inspector under the jurisdiction of the Real Estate Board or Commission and the HI Associations that are out there either can't work together or agree to this blatant conflict of interest. There are many of us (mostly the old electricians, contractors and building officials) who are advocating; 1)Home inspectors should come under the state entity that governs tradesmen (electricians, plumbers, contractors, etc), this will better insure knowledge, training and experience and get them out of bed with the real estate agents; 2)Not allow the real estate agents to refer buyers to home inspectors; 3)Not allow the home inspectors to solicit real estate agents (I do advertising that targets the buyer, but will not solicit agents).
One thing that needs to be done is for the trades to work with the states and local jurisdictions and the home inspectors to get these laws passed.
I for one am tired of the government butting into my business. But, to protect the public and stop some of the BS write ups, we need these laws.
Bob
John,
Here in northern NJ, we only give the CCO's to commercial property not the residentials. Even so, not all towns give CCO's, out of 4 towns that I work for, only 2 have CCO's.
Interesting Link here to ASHI, portarying the HI criterior in about 1/2 the states.
The obvious differences are apparent, as some states require credentials ,continuing ed, liability insurance, etc.
The states not listed (like mine) , have much litigation surrounding individual HI's .....
.... wag the dog [Linked Image]
