0 members (), 1,107 guests, and 15 robots.
#78551 10/05/01 05:06 AM
pauluk Offline OP
Yes, the 2m is probably a very generous allowance. Prior to the metric edition in 1970 it was listed as 6 ft. minimum. I'm not sure when that spacing was introduced; it's certainly there in the 1955 edtion.
Virgil:
Thanks for that link. Sometimes a bathroom light switch is located outside the door, but another very common arrangement is for a ceiling mounted switch operated by a pull cord. As the live switch is up on the ceiling, these can be mounted so the cord is right next to the tub or shower.
They're so common in bathrooms, that they're often used even when a regular wall switch would be outside the 6'/2m boundary.
Workgear for Electricians
#78552 10/05/01 08:26 AM
DS,
But the objective can be met with just 1 m of separation (30" NEC) unless you have some really tall people in which case, they are probably at greater risk for taking out luminaires with their heads.
Can I ask where the justification for your statement comes from?
#78553 10/05/01 03:54 PM
Anonymous
Unregistered
If I am in the shower, I can reach an arm's length easily. However, to reach more than 1 m, I must step out of the shower.
