181
Anonymous
Unregistered
inspectors are requiring GFCI protection on laundry room receptacles, and on sump pump receptacles before they will issue a occupancy permit. Yea!!!!!!!!!!!
>I think there may be enough stray leakage current from some of these motors to cause nuisance tripping, and in the case of the sump pump, a major problem developing when the pump loses power when its needed most. I think you are wrong. Don't put more than two devices on a single GFCI. Put the sump on a dedicated GFCI that cannot get wet - ever.
Posts: 4,116 Likes: 4
Redsy,
I would be inclined to think that there may be some problem with the sump pump or it's supply cord. Perhaps a closer inspection would reveal something.
Originally posted by Dspark: I am afraid that the moisture at the sump pump motor, not at the GFCI itself will cause the GFCI to trip and render a sump pump useless. I would prefer to mount a single receptacle (not duplex)dedicated for the sump pump behind it(inaccessible for general use) and skip the GFCI.[b]inspectors are requiring GFCI protection on laundry room receptacles, and on sump pump receptacles before they will issue a occupancy permit. Yea!!!!!!!!!!!
>I think there may be enough stray leakage current from some of these motors to cause nuisance tripping, and in the case of the sump pump, a major problem developing when the pump loses power when its needed most. I think you are wrong. Don't put more than two devices on a single GFCI. Put the sump on a dedicated GFCI that cannot get wet - ever.[/B]
Originally posted by Bill Addiss: Redsy,
I would be inclined to think that there may be some problem with the sump pump or it's supply cord. Perhaps a closer inspection would reveal something. Bill, No particular application in mind. Just an overall concern that the pump may not perform when needed. Bill
Redsy,
Perhaps, depending on location and other factors, they may allow a single receptacle that is non-GFCI protected. I believe that the code would permit this.
today's basic electrical rules, water & people = GFI do not necessarily apply across the board. some of this, as far as NEC rules, makes sense to me, some does not. some , i suspect, are simply awaiting the Darwinian factor to come about.
Anonymous
Unregistered
So let your sump trickle away milliamps all day. Waste energy. Have a higher bill. Sump pumps are very expensive. Ones that are electrically sound are even more expensive. Just put in a dedicated outlet and leave it there until it leaks bad enough to blow the circuit breaker.
Redsy,
Sorry, I didn't see that you had mentioned the single receptacle already. All this quoting and Bold lettering is a bit confusing. Have you tried suggesting it to them or expressed your concern?
I would see no reason to agree with them about the Laundry room receptacles. It makes things safer and tripping would cause no harm. As far as the Sump Pump goes I can see your point but it is a tossup as far as which is the lesser of 2 evils. Bottom line though is that it's their call. A GFCI could save a life. With nuisance tripping the most likely worst case outcome would be property damage. That may be the way that they're seeing it.
Bill Bill, I never debate the issue with the twp. I just do what they require. I just thought it was an interesting issue.
Redsy,
What's "twp" stand for?
I agree it's an interesting issue. I'm not sure which way I'd want to go on that. It would depend on where the pump is I guess and the likelihood of it being needed.
I will always try not to put a Refrigerator or Freezer on a GFCI because I've seen many instances where power surges and such have caused a GFCI to trip. I wouldn't want it to happen while I was away on vacation. I guess it's a calculated risk at best.
