0 members (), 1,437 guests, and 15 robots.
#75937 03/21/07 07:27 PM
Grover Offline OP
Landed a big job - 100's of #16 THHN need to be cut, re-labled and terminated in DIN blocks.
Looked around, and finally bought the DYMO Rhino 3000 (got lots of sequential PLC terminations to do) because it promised to allow "serialization" of lables - sequential numbering.
Problem: Dymo has a minimum lable length of 1.5 inches. It allows you to set fixed length to less, but the default overrides.
At lotsa bucks per 5' spool, I'm wasting 1" for every 1/2" lable I print. Seems like they want to sell a lot of spools!
Where did I go wrong? Anybody got a better solution? What are you using? I'm about ready to return the unit, but go back to handwriting.... frown
Thanks for help guys...
Grov
We use the Brady LS2000 and either vinyl labels (frosted/clear) or Permasleeves. I guess your problem is similar to what I deal with on my Brother P-Touch at home. I try to print several at a time with a few spaces between them so I mimimize the header/footer waste. If you don't need both ends of your cables marked and need every marker serialized, I guess your stuck with the waste.
Joe
I have the brother, same problem. What I do is make one long label with as many numbers as the buffer will hold. Just put a few spaces between them. You still waste the inch, but only once per strip of labels.
I have Brother P Touch. Same problem and do same as above two people do.
You may want to check out the Brady IDpal. There are various formats available including ones for wire wraps. You can set the required diameter too.
http://www.bradyidpal.com
They also make a desktop version. This link is for the handheld.
