2 members (Scott35, gfretwell), 409 guests, and 21 robots.
Page 3 of 3 1 2 3
#70368 10/09/06 01:33 PM
"BTW, Rowan Atkinson allias Mr Bean, is a fully qualified electrical engineer."
I can just picture him at his drafting table or computer with a turkey on his head.
Sixer
#70369 10/09/06 02:14 PM
IMO, I don't think most paints would be detrimental to a receptacle but UL doesn't seem to like the idea..
In the last question on this page UL doesn't condone it but they don't flat out say it can't be done either.
Roger
[This message has been edited by Roger (edited 10-09-2006).]
#70370 10/09/06 08:10 PM
e57 Offline
When paint is introduced onto the face of the
receptacle, the ability of the receptacle
face insulating material to resist
a potential arc across the face of
the receptacle from one contact to
another may be compromised. It is
impossible to determine the effect
paint will have on the electrical integrity
of the receptacle.
Roger, I would take that as a NO....
#70371 10/09/06 08:39 PM
Mark, I pretty much agree, but with no more of a solid statement as an answer to the question it wouldn't hold much weight.
The problem is
may be compromised
that statemnt means it "MAY NOT" be compromised as well.
It would seem as though a "yes it would void the listing due to" or "no, it is not permissible to paint a receptacle per the listing blah, blah, blah," would be the solid statement needed to have any strength.
Roger
#70372 10/09/06 09:14 PM
When UL says "May be", or it's twin "has not been evaluated"...that's just a fancy way of saying "we have no way of knowing.
Not all paint is alike. Nor are all receptacles. An oil / xylene based paint (such as "Rust-O-Leum") is more likely to attack a cheap plastic receptacle than a water-based latex. UL doesn't know what paints may be used, and does no tests of this sort.
Likewise, some paints have a lot of rubber solids; these probably provide decent insulation. Others have a fair amount of metal in them; I suspect that those just might conduct....
Sometimes "don't know" means nothing more, or less, than "don't know."
Page 3 of 3 1 2 3
