1 members (Scott35), 405 guests, and 18 robots.
#67072 06/29/06 12:52 PM
quote"However, the big question would be: why does anyone need an outlet there anyway??? A ceiling light or wall sconce should be well enough."
I get to put them in all the time in situations like this. Thats because I do lots of work for folks with ties to Japan. They all really seem to love having an electric toilet seat that sings them a little song, and heats up when in use. I stick in a gfi , collect my dough and beam over to the next job....
#67073 06/29/06 08:13 PM
e57 Offline
I too will ditto that it is a "Water Closet", by victorian terms...
But by the NEC version, it would have to have a basin...
Bathroom. An area including a basin with one or more of the following: a toilet, a tub, or a shower.
However the commentary to 210.8 (Not considered CODE.... And subject to interpetation.) defines it slightly differently
A bathroom is defined in Article 100 as an area that includes a basin with one or more of the following: a toilet, a tub, or a shower. The term applies to the entire area, whether a separating door, as illustrated in Exhibit 210.9, is present or not.
Shows a tub and toilet in seperate area, from the basin. But also doesn't show outlets in there either.
#67074 06/29/06 09:30 PM
Does it ever occur to you that NFPA does this on purpose to ensure the need for another Proposal/ROP/ROC cycle and another batch of books you have to buy?
Call it job security.
[This message has been edited by gfretwell (edited 06-29-2006).]
#67075 06/29/06 09:39 PM
e57 Offline
Luckily the code cycle around here only seems to change every 6 years or so... 93-99 And in 2005 we went to 2002.... [Linked Image]
#67076 06/29/06 11:05 PM
Hey Rad,
Maybe I should have put a weatherproof cover on it!
#67077 06/30/06 08:10 AM
You're joking, but last summer I was looking into a job with the Orient Express company, and one of the cars did have a Swiss 220V receptacle conveniently behind the toilet bowl!
We joked about killing the feed but leaving the receptacle in place, adding a huge warning sticker to improve the aim [Linked Image] [Linked Image] [Linked Image]
