Electricians revenge
1 members (Scott35), 184 guests, and 13 robots.
#65287 05/03/06 09:28 AM
Paul:
Excellent description - complete with the pix. I'm curious as to what kind of terminal connections that little switch has. It looks kinda like the set-screw type connections used on circuit breakers.
#65288 05/03/06 10:11 AM
SvenNYC Offline OP
Brass sleeves with setscrews. Same kind of connection they use on sockets and plugs.
Beats wrapping a hook of wire around a screw anytime. [Linked Image]
#65289 05/04/06 06:20 AM
Sure, but you can't just connect more wires by using a longer screw! [Linked Image]
I know a guy who claims to be able ton hook up 4 wires to a screw terminal rated for 2...
#65290 05/05/06 07:56 AM
Here's a closer look, one terminal with a conductor in place:
Looking through the brass collar from the rear:
These tumbler switches were generally mounted on a wooden block, the latter having holes drilled to match the terminal locations so that the wires could pass through.
