0 members (), 409 guests, and 14 robots.
#63404 03/14/06 05:01 PM
I am having a bad day......
This is what I got. I had the landscapers build me a column at the end of my driveway. I was intent on putting a motion detector/photo cell combo in the column. This way the lights on the front of my house and the driveway lights could come on automatically with the photocell for a given time, and then go out. Then If I came home late, when I pulled in, the motion sensor would trip and the lights would come on.
I can't seem to find such a device, that is outdoor rated for a Sg box....
I need help on this one...
Anyone done this or seen such a thing?
I would ideally like to match the pewter block..(not asking too much) [Linked Image]
Dnk....
#63405 03/14/06 05:54 PM
Big box stores have replacement detector heads with 1/2 inch male hubs that might work. They are for the regular flood lights that go on the outside of a building. I mounted the lights up near the peak of my garage for maximum spread but didn't want to climb way up there to make adjustments to the detector so I remote mounted it on a box 8 feet below where a short ladder can be used. They come in white or black.
Alan--
Alan--
#63406 03/14/06 06:07 PM
Those heads that Allan mentioned... I find the ones made by " Heath Zenith" to be about the only ones that work properly... I reccomend that brand if you can find them
#63407 03/14/06 06:50 PM
Not them kind fellas, that would look ugly sticking out of a column...
Not a head like flood lights, but more like a indoor occupancy sensor that fits into a SG box. But has a photocell built into it..
But are they made for outdoor use?
My google, googled my brain. Maybe I'm typing in the wrong info for search....Ugh
Dnk...
#63408 03/14/06 08:39 PM
Dink...look at the motion sensor light switches a bit closer....most of them have a photosensor built in, so they will operate lights only at a certain, settable level of darkness.
Of course, you would still need a timer wired in parallel for the "constant on" period. While they make one that fits in a switchplate, and they claim to have fixed the bugs...well, the early ones were junk.
#63409 03/14/06 08:44 PM
LK Offline
Dnk,
What will the total load be, with all the lights?
#63410 03/14/06 08:58 PM
les, less than 500W, maybe 300....
Dnk...
#63411 03/14/06 09:37 PM
LK Offline
Ok the reason i ask is the sensors usually don't hold up with 150W max, you may want to use a contactor, i have X10 control for all lighting, i turn on the lights in driveway, or back of house, from car, or trucks, with key fobs, works great, and less hard wiring.
#63412 03/14/06 10:08 PM
Les, a contactor wouldn't be out of the question, just finding the unit I'm looking for is being the hard part...
Dnk..
#63413 03/14/06 10:49 PM
WFO Offline
Probably a stupid remark on my part, but make sure you don't put it where your headlights turn the darn thing off.
