Electricians revenge
1 members (Scott35), 183 guests, and 10 robots.
#63228 03/12/06 12:00 AM
renosteinke
BTW....does anyone have the EXACT text, or can they cite, the "10 ft rule" rfered to in the article?
try this on:
1910.333(c)(3)(i)(A)
When an unqualified person is working in an elevated position near overhead lines, the location shall be such that the person and the longest conductive object he or she may contact cannot come closer to any unguarded, energized overhead line than the following distances:
1910.333(c)(3)(i)(A)(1)
For voltages to ground 50kV or below - 10 feet (305 cm);
1910.333(c)(3)(i)(A)(2)
For voltages to ground over 50kV - 10 feet (305 cm) plus 4 inches (10 cm) for every 10kV over 50kV.
Above from:
Selection and use of work practices - 1910.333 http://tinyurl.com/pla2e (Had to reduce OSHA's link)
Here are a few more links:
A Guide to Scaffold Use in the Construction Industry Small Business Safety Management Series
OSHA 3150
2002 (Revised) http://www.osha.gov/Publications/OSHA3150/osha3150.html
Frequently Violated OSHA Standards Related to Overhead Power Lines in the Construction Industry
January 1, 1995 - February 8, 2000 (Sequential Order by Standard) http://www.osha.gov/Region7/overheadpowerlines/elecstds.html
OVERHEAD POWER LINES - DON'T GET ZAPPED!
EMPLOYER KIT
February 3, 2003 http://www.osha.gov/Region7/overheadpowerlines/index.html
~~ CELTIC ~~
...-= NJ =-...
#63229 03/12/06 12:20 AM
Our Power Companies here have a system where if we are notified of impending work near our lines, we will sleeve them for free
Here's one of our guys doing just that:
Anything less is a bad excuse for safety practice. [Linked Image]
#63230 03/12/06 11:06 AM
That's quite common here as well. When scaffolding is up for work on a building, you'll often see bright yellow sleeving over the lines which has been fitted temporarily by the PoCo.
#63231 03/18/06 11:00 PM
Most poco's come out witin a day or so in my area. I got a call from a roofer who said they hit the service cable lifting a material pulley to the roof. When I got there I saw they actually hit a hi tension wire and it blew the capping off the roof started a fire and blew a hole thru the side of the pulley. That is the problem some contr. never put safety first it would have been a simple call to have the wires protected.
