0 members (), 628 guests, and 12 robots.
e57 Offline
"Bring some barbecue sauce with you because the'll grill you."
At least around here, the IBEW has a thing for BBQ's, it is a major portion of their annual events. Bringing sauce could make or break you - depending on flavor and prefferance....
[Linked Image from asihome.com]
Be prepared to answer questions w/o hesitation (same goes for any interview).
Have an answer for this gem (that seems to asked by a lot of employers - IBEW or otherwise):
WHY do you want to be an electrician?
HINT:
Your answer should include...
- I like to be wired
etc
Seriously, that question will probably be asked.
Dress nice - but a tie might be overkill.
[This message has been edited by Webmaster (edited 02-06-2006).]
~~ CELTIC ~~
...-= NJ =-...
This is good advice. Dress casual, but comfortable. No one will be impressed if you show up in a suit. This is not a suit and tie job.
I can scan the sheet they gave me before I went for my interview. It doesn't have much useful information on it, but it may help you some. Let me know if you can use it.
F
Tell them that Black and White make Light and that if you add a red wire you can make magic things happen to a fancy switch.
They will be highly impressed with you and probably make you a foreman..
