Electricians revenge
1 members (Scott35), 179 guests, and 6 robots.
#52915 06/12/05 06:03 PM
LK Offline
Keep on using those butt connectors, they give us a lot of work every winter, this past winter we had to replace 12 service connections, it appears when the wind blows they loosen up and the connections fall apart, keep up the good work.
We replace with split bolts, no call backs, or angry customers.
#52916 06/12/05 08:26 PM
Will do.
[This message has been edited by Electricmanscott (edited 06-12-2005).]
#52917 06/12/05 09:11 PM
LK Offline
Scott.
They made butt connectors back in the 60's that had 4 bit points on each connector, and allen sets, they worked pretty well, I notice, the ones on the market now have only one contact point, and i believe this is weak point.
Our connection is it, utility does not crimp.
#52918 06/12/05 09:26 PM
H-Taps (parallel groove) here, too.
The tool is expensive, but the connectors are much cheaper than split bolts, and with the snap-on cover, the time spent taping the bugs is also saved.
#52919 06/13/05 12:19 AM
I like the polaris connectors:
http://www.polarisconnectors.com/black.html
#52920 06/13/05 08:48 PM
I agree with Active 1 Polaris connectors are what we always use(safety and quality). Granted they are not the cheapest but thats the route I'd go.
Local 175
#52921 06/17/05 10:43 PM
nov Offline OP
if you had to choose between a split bolt or a self piercing tap which would you use. I ordered the compression sleeves but they will not be in for a few days and we have a couple of services to do in the mean time.
#52922 06/19/05 12:07 AM
Way back, when I was a helper, we used Tomics as temporary splices after a service upgrade, until the POCO got there.
Hey, what did I know?
Larry Fine
Fine Electric Co.
fineelectricco.com
#52923 06/19/05 12:39 AM
Polaris IT Series, minimises handeling live connections.
Rob
#52924 06/19/05 06:20 PM
ya let the power co. do it.
But in the past I've used two screw romex connecters 3/4.
just for temp tell the pco. comes.
