1 members (Scott35), 414 guests, and 29 robots.
whare do I find the ampacity of NM?
bucketman: 310-16 60 degree column
We are allowed to use romex in metal studs here as long as you use gromets through penetrations of the studs.
Electric Eagle, thanks.
For 14,12,10 you really need to look at 240.4(D)
so whare does it tell us to us the 60c column
for the ampacity of NM.
I know about the small conductores in 240.4 (D) but what about every thing else.
I was looking at 6/3 NM and theirs no temp rating.
cool thanks
cgw Offline OP
There should be no code issues (as the assembly space is for less than 100 people).
The owner is really looking for ways to cut cost. They already took out the air conditioning.
I think we will still use metal boxes.
Does any one have problems with running NM cable in small commercial wood frame buildings (say a apartment complex office/community center (less than 100 people)) as opposed to MC cable?
Is the cost savings (material and labor) significant?
I have no problem whatsoever. NM would be the preferred way here assuming correct building type and no code restrictions.
The cost savings could be significant given the price difference. A spot check of prices is about $120/M for 12/2 NM cable and $240/M for 12/2 MC cable.
Peter
[This message has been edited by CTwireman (edited 02-25-2005).]
Peter
