Electricians revenge
1 members (winnie), 173 guests, and 9 robots.
#48058 02/02/05 11:21 PM
Roger, thanks for the tip. Pauluk... you can pass this on. Your post said this was in an American home. Maybe someone will get the benefit out of it.
#48059 02/03/05 04:27 PM
pauluk Offline OP
Thanks for all the ideas guys. My initial reaction to the problem was to suggest simply fitting the chandeliers with suitable 120V bulbs (after checking that the fixture wires will handle the higher current of course), but the lady said she couldn't locate any American 120V bulbs of the special design that she wanted to keep. I didn't think to ask whether the bases are normal ES or something different.
Ultimately, it may be a case of settling for a different type of bulb. I would think that in the huge range available there is something acceptable, even if not identical to the originals in style.
The underrun "mood lighting" idea would certainly help those hard-to-obtain foreign bulbs last longer! [Linked Image]
[This message has been edited by pauluk (edited 02-03-2005).]
