Electricians revenge
1 members (Scott35), 184 guests, and 13 robots.
Page 1 of 6 1 2 3 4 5 6
#42033 09/15/04 06:48 PM
bot540 Offline OP
Do you think its a bad idea to use a 1900 and extension box for second floor homeruns? The guy I used to work for would often do this in two or three of the switches so he could come out the top of it 6 times instead of 3.
Jesus may have been a capenter,but God was an electrician.Genesis1:3
#42034 09/15/04 07:31 PM
I have never had the need to do something like that but as long as you can maintain the required 1-1/4" for the cables from the face of the studs, the required conductor length in the box and the box fill I see no problem.
-Hal
#42035 09/15/04 08:55 PM
My old shop used to used deep 1900's instead for all the HR's, with 3/4" (EMT) to the panel.
#42036 09/15/04 09:37 PM
What is a 1900 box. I see you guys mention it all the time.
Edward
Thanks
Edward
#42037 09/15/04 10:21 PM
a 1900 box is the most common type of electrical box. you can fit 2 switches or outlets in it.
#42038 09/15/04 11:20 PM
What is a 1900 box. I see you guys mention it all the time..
... Edward, a "1900" box gets it's name from a Raco manufactured 4"X4"X 1-1/2" metal box..their item/model # is 190,...hence the term "1900"...
Russ
[This message has been edited by Attic Rat (edited 09-15-2004).]
#42039 09/15/04 11:27 PM
I thought the 1900 was in reference to 19.00 cubic inches, but it's actually more than that.
Dave
#42040 09/15/04 11:52 PM
In other words it is a shallow 4S box.
Right?
Thanks
Edward
#42041 09/15/04 11:55 PM
Bot540,
why not use a 5s deep box?
Edward
Thanks
Edward
#42042 09/19/04 07:47 PM
CJS Offline
The topic is "residential" homeruns: Why would anyone want to use a metal box in residential? It seems like a BIG waste of money to me...
