0 members (), 560 guests, and 20 robots.
#39605 06/26/04 08:31 PM
I recently did some work in a conference room. When I completed the job, I went to the panel to turn the power back on- and was rewarded by a loud "POP." Turn it off, check it out, turn it on, another "POP."
Finally realised that I was hearing the audio feedback when the microphones re-energised!
#39606 06/26/04 09:02 PM
I had one like that some years ago. Changed out a receptacle and after I turned the power back on, went to check the voltage. I was standing in front of the receptacle and I hear this hissing, sizzling sound. I go and turn the breaker back off, take off the receptacle cover plate, check the connections and the splices to make sure they're tight.
When I turn the power back on, I'm standing in front of the receptacle and I hear the sound again. I squat down and am looking at the energized receptacle to see if I see an arc anywhere, and I notice the sound doesn't seem to be coming from the receptacle at all. It's coming from my boot!
It turns out there was a space under the sole of my boot, when I put weight on my heels, it would compress the space and force air through the crack in the boot-tread, which made a very distinct hissing noise.
-John
#39607 06/27/04 06:13 AM
Yep, I've had cases where I thought I heard something arcing and it turned out to be something quite harmless.
Also had a couple of times where I thought I actually saw flames coming from a meter and panel area. Turned out to be reflections from a fireplace! Phew!
#39608 06/27/04 08:50 AM
Sometimes I get a twinge in my hand or arm & think I'm getting a shock..I jerk my hand away & it gets my heart pumping. Who needs coffee?
Dave
#39609 06/27/04 12:46 PM
... Once, in a house,we had to power down the Mains,and when we powered it back up again,the house's burglar alarm siren went off..literally about 2 feet from my ear,..nearly jumped out of my skin on that one,...my helper almost peed himself laughing!!! [Linked Image] [Linked Image] [Linked Image] [Linked Image]had to phone the central station,...what a day!!!
Russ
#39610 06/27/04 08:15 PM
One of those times that we absolutely had to work on a hot circuit (480v three phase) I didn't notice the intercom speaker. Just as I was about to cut the wire, the bell went off for some reason. I nearly jumped off the skyjack.
Of course evrybody else was rolling on the floor.
#39611 06/28/04 11:50 AM
Ohhh yeah! Flashback!
I had a call to a childrens daycare center once... Partial power problem (wish I had the cam back then! [Linked Image] ) Anyways, the place had an addition put on the back in the 70's adding some AL romex & a new panel, subbing the old panel...
I get there & open up the 2 panels (Zinsco service equiptment & FPE Sub) & read power on all circuits (Now we know better than to think an FPE would trip, right? [Linked Image] )
Everytime I go near those panels I'm getting wiffs of "that electrical burning" smell... I put the tone trace on the bad circuit & lo & behold, I find another whole panel! (Square D XO) This panel is ½ sandwiched in the wall where the addition was put on.. the homeowner was told it wasnt in use anymore... Busted the wall out to open the panel & a nice poof of smoke came out & one of the breakers were in full internal meltdown...
I sat the deceased XO on a trash can behind me, replaced it & went to test everything.. Circuits back on... Im inside for about 30-45 mins going over ideas to clean up the panel mess they have (Aiming at 86ing all 3 old boxes & using a 200A 40 space for everything) Anyways, I go back out to button everything up & I start getting that wiff again....
sniffing around the panel, not as strong there... Where's that friggin smell coming from now? I open all panels back up, a couple J boxes... Start going through the AL wiring on the other side of the wall in the addition... about 2 hours of searching & it dawns on me... the stinky XO is on the trash can [Linked Image] Ive never had a breaker go out & make an odor THAT strong! I NEVER would've gotten to sleep that night if I hadn't figured that smell out!
-Randy
#39612 06/28/04 12:12 PM
Part of my time is spent working with a magazine that produces articles about residential electrical wiring. On occasion, I'll be called in to mock up a photo set for a kitchen or other space so it looks real to the camera.
These sets are total stage prop affairs. . .intended to be destroyed after use, so, there is never a working circuit. The appearance of reality is only as far as the camera sees.
While putting the set together, the photographer will be tweaking his lighting and/or taking shots of finished parts of the set. The lights he uses are photo strobes with very effective xenon flash strobes.
Try as I will I cannot escape the adrenalin rush and convulsive recoil that occurs if I happen to be cutting conductors and the photographer forgets to holler "FLASH!"
Al Hildenbrand
