0 members (), 546 guests, and 27 robots.
#36901 04/18/04 04:26 PM
Edward Offline OP
If I have a PVC underground feed do i need a conduit hub?
Thank you
Edward
Thanks
Edward
#36902 04/18/04 04:59 PM
Ermm, what's the PVC connnected to? [Linked Image] At the pole?
[This message has been edited by hbiss (edited 04-18-2004).]
#36903 04/18/04 05:10 PM
Edward Offline OP
to the meter main panel.
Edward
Thanks
Edward
#36904 04/18/04 05:46 PM
A PVC Male Adapter and locknut is all we normally have to use.
#36905 04/18/04 08:40 PM
Depending on the tempeture variation in your weather you may also need to use a PVC expansion joint.
ed
