An impossible Support Violation
by gfretwell - 09/12/23 04:29 PM
How are you Jersey folks about the windmills?
by gfretwell - 09/08/23 02:21 PM
Having trouble logging in?
by Admin - 09/01/23 10:26 AM
New TikTok Challenge Posing Serious Risks
by iTacos - 08/28/23 10:04 AM
Mis-applying Codes
by gfretwell - 08/25/23 05:31 PM
Get Back to work, Keep Using it.
1 members (Scott35), 16 guests, and 13 robots.
#36901 04/18/04 04:26 PM
Edward Offline OP
If I have a PVC underground feed do i need a conduit hub?
Thank you
Edward
Thanks
Edward
#36902 04/18/04 04:59 PM
Ermm, what's the PVC connnected to? [Linked Image] At the pole?
[This message has been edited by hbiss (edited 04-18-2004).]
#36903 04/18/04 05:10 PM
Edward Offline OP
to the meter main panel.
Edward
Thanks
Edward
#36904 04/18/04 05:46 PM
A PVC Male Adapter and locknut is all we normally have to use.
#36905 04/18/04 08:40 PM
Depending on the tempeture variation in your weather you may also need to use a PVC expansion joint.
ed
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
CharlieE
CharlieE
Indianapolis
311,074 Are you busy
237,472 Re: Forum
221,260 Need opinion
