0 members (), 193 guests, and 14 robots.
#36762 04/14/04 08:34 PM
LK Offline
A fan installation is not a rubber stamp price, How high is the ceiling, will it need special support, is additional circuit wiring needed, how long is the assembly time for the fan or fan light, are we moving anything to get access, is the switch circuit existing or are we running a switch.
Our actuals show the average fan install not including the fan, is 280 to 350, so this ad is close, if you include the fan with markup.
If you are in business, and have overhead expenses, the prices in the add may even be a little on the low side for my area.
[This message has been edited by LK (edited 04-14-2004).]
#36763 04/15/04 12:50 AM
Ahhhh I know these guys! [Linked Image]
I had a partial kitchen power call where "someone" didn't tighten a neutral screw on a counter recept, The connections melted, as did the "nightlight" plugged in the same recept.
As far as prices for my company
Motion sensors (existing wiring) $229.49
Add'l wiring & box $236.89 up to 25'
ceiling fans were the same pretty much unless the ceiling is cathedral style or over 10'.
Then add $60.00 for wiremold (on cathedral beams) &/or pulling that pain in the *^$# 12' ladder off the truck & not dinging up any walls!
-Randy
#36764 04/15/04 03:55 AM
BTW as far as installing motion lights goes-I hate those things.
Second that. They've become all the rage in England in recent years as well, and I'm not that keen on them.
People are frustrated when they find out that the advertised 30 ft. detection range over a 110-degree angle actually becomes more like 15 ft. over 30 degrees and 10 ft. over 30 degrees either side of that if they're lucky.
#36765 04/15/04 07:17 AM
I think it's brilliant advertising.
The consumer has no idea what it costs to do work on their homes. Putting the price in print makes it "The Price" firm and believable. No haggeling because they know this contracotr's price up front. And they worry what the other guys might charge (even if it's really going to be less).
And probably most importantly it keeps the price shoppers away that can't afford it or won't part with the money. Less wasted time with people who never buy.
#36766 04/15/04 11:31 PM
Good point maintenanceguy.
With those motion sensors, always let the customer know right away that the price includes installing and wiring only. NO adjusting.
It gets a little more complicated though when you have the wealthy customer that hires out EVERYTHING (even walking the dog) and you need a 24' extension ladder to adjust.
Then make sure the sensor light being installed is of a reputable brand (I like the Journeyman from HD) and that the price to install has enough figured in.
