0 members (), 297 guests, and 8 robots.
#36514 04/09/04 06:18 AM
With the price of steel up as high as it is, I thought that I had a brainstorm.
We checked into the price of aluminum EMT (available in sizes 2-1/2" to 4"). Guess what?
It's doubled in price also.
Has the price of aluminum wire gone through the roof, too? (we never use it)...S
#36515 04/09/04 08:03 AM
K
I think the aluminum has gone up simply
because the steel has gone through the roof.
I have been in the electrical business since
1992 and i dont think i have ever seen the
prices that we now face.
#36516 04/09/04 08:48 AM
Aluminum is still very cheap the last time I checked, at least AL wire.
From eveything I have read in the paper, high prices on gasoline, CU wire and conduit are here to stay. The only thing we can do is get used to it. [Linked Image]
Peter
Peter
#36517 04/09/04 10:59 AM
Last week my purchase price for 3/4" EMT a ft was about .24 this week it was .526 In cents it doesn't look like much, but it is more than double!
Have to closely watch your bills and charge accordingly.
#36518 04/09/04 11:50 AM
K
within the next couple of weeks
1/2" emt will be in the 30.00c range
#36519 04/09/04 05:04 PM
Electure,
Ever "rippled" a piece of Al conduit when bending it?. [Linked Image]
We used this stuff when I first started my time, I hate it.
Oddly enough at the time, I remember thinking that someone in the Industry here must have had an Aluminium fetish, everything was made of it, glad we won't be using that stuff again!. [Linked Image]
#36520 04/09/04 06:04 PM
Tom Offline
I used a good bit of Aluminum rigid conduit years ago, I don't remember having any trouble threading it or bending it. Maybe the contractor I was working for had special shoes for the bender.
I was quoted $.30 ft for 1/2" EMT this week, price was good that day only, 12 THHN stranded was quoted at $76/M
Now if I could only double my labor charge...
#36521 04/11/04 09:40 PM
Oh yes, Trumpy,
I've "rippled" (more like kinked) aluminum.
I've also had some turn out good too, even with the Al EMT. [Linked Image]
#36522 04/12/04 03:57 AM
Sorry Electure, what is EMT made from?.
Steel?.
I've bent Galvanised Steel, Aluminium, and Pyrotenax(pyro)and Copper Refrigeration tubing, both soft and Hard-Drawn, 1/2", 3/8",5/8", 3/4" and 1 inch plus 1 1/2".
I'm just a Boy as far as Refrigeration systems go though!. [Linked Image]
#36523 04/12/04 07:24 AM
Trumpy,
EMT (Electrical Metallic Tubing) is also some times called thinwall conduit.
It is made from steel in 1/2" through 4" trade sizes.
It's also available in aluminum in 2-1/2" through 4" sizes.
The aluminum is much lighter and is easier to install in the larger sizes.
The downside is that there's a lot more surface friction with the aluminum, so pulling wire in takes a lot more lube, power, or both...S
