0 members (), 394 guests, and 18 robots.
#3531 08/22/01 05:50 PM
Originally posted by Dspark:
I have seen lightning damage done when the telephone was not bonded to the electrical GES.
Is it currently standard practice for lightning arresters to be fitted on tel. lines where they enter premises?
This isn't done here, but then we don't get anything like the number or severity of storms that many parts of the U.S. get.
#3532 08/22/01 06:13 PM
I see a lot of older telephone entrance that has a lightning arrester, usually it is two 3 or 4" cylinders about 1/2" in dia.
I don't see this on newer installations.
#3533 08/22/01 06:19 PM
Anonymous
Unregistered
The old ones had the gas discharge tubes you described. The new ones have something different. But they still must be bonded to the AC system's GEC.
#3534 08/23/01 01:43 PM
Do they perhaps use MOVs (Metal Oxide Varistor) as the modern equivalent? These seem to be the current method for surge protection in power strips and tel. line protectors for computer equipment.
#3535 08/23/01 05:00 PM
Anonymous
Unregistered
I haven't opened up the telco side to check. I'll have to look.
My guess would be a cheap choke that shunts the magnetic field to ground.
MOVs would have to be checked after every event and replaced if damaged. MOVs are relatively expensive compared to iron chokes.
#3536 08/23/01 05:18 PM
I have seen nothing to insinuate this protection on the premisis, perhaps it would be on the pole??
#3537 08/23/01 06:17 PM
Anonymous
Unregistered
>I have seen nothing to insinuate this protection on the premises
Seriously? All telephone network interface boxes have a solid copper wire attach to the GES or similar and tagged with a statement to the effect that the wire must not be disconnected or else the house will burn down and if you see one disconnected, call the telco.
