All that I did back when we bought this house was backyard specials workshop, and always had a tarp handy for the pop up t’storms.
Neighbor’s workshop has been his driveway as his garage/shop is loaded with materials for the extensive project he’s into. He has tarps also.
My wood projects were new slab solid pine doors, routed hinges, drill knobs, etc., sand/stain/poly &hang. Oak pre finish flooring, trim molding, shelving, chair rail, exterior doors (pre-hung & finished). Oh, to have a shop!
My God Bill, You should be totally proud of that effort, especially the router work. I bought myself a router 3 years ago and while I've used it for simple housing joints, profiling the sides of timber sections and what have you, I don't think I could even come close to that. And let's be fair here, having something like that on show in a kitchen, it needs to be PERFECT, especially for domestic harmony and when your guests look at it, it needs to prevent them from saying "How much did that company charge you for THAT??!!"
If I got serious about it I would need a better table saw. This old Craftsman has been beat to death and it was a low end saw when I got it. I have cut everything from steel plate to pavers and then I try to make a precision cut on a piece of mahogany
My Dad had a full shop in his basement. I wish I had room for some of his equipment, but I didn’t. I just have a portable Table Saw that I built a table around. It extends to the left side and there’s a drop leaf in back.
My grandson helped with the table build.
Mine had the 16 ga pan extensions. I took the one on the right side, where the fence rides, off and mounted a router in there on a beefed up extension. Now I can use the fence and the guide slots for a sled with the saw or the router. I also drilled some holes for pins so I can cut and edge circles with the router. I have also made some jigs for different things with MDF.
I haven't seen it for a while but PBS has a show called "Router Workshop" with a couple of guys from Canada. They do amazing things with routers. The "Woodsmith Shop" is good too if you have all the tools to keep up. OTOH if you like old school Roy Underhill "The wood smith" does it all with hand tools.
