13
12
Been patented for 5 years but thankfully no one has manufactured it https://www.mikeholt.com/newsletters.php?action=display&letterID=2223&email=bwinkle4@cox.net#comments
Posts: 9,788 Likes: 14
This also assumes nobody swapped the white and black along the way. The scary thing about that is your 3 light tester would say it was fine but the case of your drill would have 120v on it.
This also assumes nobody swapped the white and black along the way. The scary thing about that is your 3 light tester would say it was fine but the case of your drill would have 120v on it. I hadn't thought about that scenario, and we see it a lot. It reminds me of the electronics kit I had when I was a kid, it came with a radio antenna wire that had a blade on the end to plug into the neutral slot of a receptacle and use the building wiring for an antenna. The blade would only fit the wide slot on a polarized receptacle. I think about that a lot, what could have happened had someone mis-wired the receptacle. The kits were marketed to young electronics minded kids and students.
I always used the center screw on the cover, using the EGC. Back in the analog TV days you could get a decent picture on a TV with that. Later I strung a long wire antenna to a post we installed behind the house. I wired it to my "All American" tube radio for AM DX'ing. I would be scared to do that here because of lightning. It was pretty cool though for a kid. On a clear winter night I could get radio stations from a thousand miles away.
Yep I would listen to AM radio from Tucson, KOMA in OK City, WLS in Chicago. I believe KOMA was 50,000 watts. Then there were the mega watt stations South of the border. I listened to the one in Monterrey a lot. I had a 50 foot wire stretched across the roof and a little 9 volt Toshiba shortwave and I would sit on the roof at night and listen to the whole world.
Those 50KW clear channel stations were pretty easy. The trick was getting one that was more like 15-25KW and not stepped on by another station.
