0 members (), 705 guests, and 17 robots.
Page 13 of 14 1 2 11 12 13 14
dsk #218544 06/15/17 03:34 PM
dsk Offline
Originally Posted by dsk
Maybe not always.
The lightning has hit and the grounding wire is off! As long as I stay on the ground this should be safe. or ??
I post this, and sends link to the owner of the network, and asks for comments and followups on this page.
As far as I know this supply is 3 phase delta 22kV with no fixed grounding of the transformer winding. I hope we may get some response here. thanks
Until now, it is still not repaired.
Meadow #218550 06/19/17 03:24 PM
A thank you from a power company yeah good luck with that
Meadow #218551 06/19/17 03:40 PM
dsk Offline
I did hope this would be something different, and make them look at it. Obviously not.
How dangerous might this be? Probably worst for the transformer close to. I do not use to stand and lean to those poles in bad weather. :-)
Meadow #218611 07/10/17 05:19 PM
dsk Offline
I could not resist to share this picture. It is not by code! When you biuld a house and a neighbor has their drop running over your property, you temporarily fix the wire in a tree, cuts down the pole, and builds the house with the wire going trough! crazy Then you may get it solved when you get the powercompany to connect your house, and hopefully just pay for one visit. smile Ill guess the risk never has been evaluated, but this is a cable with 2 wires, 230V between, and approx 127 V to ground.
dsk
Meadow #218661 07/30/17 08:46 AM
dsk Offline
Some more pictures, even worse!
dsk #218662 07/30/17 08:48 AM
dsk Offline
more
Meadow #218663 07/30/17 08:48 AM
dsk Offline
more
Meadow #218664 07/30/17 08:49 AM
dsk Offline
last so far
Meadow #218710 08/26/17 01:43 AM
Awesome thread, thanks DSK! smile
And yes, have not seen pics like that before.
Meadow #218711 08/26/17 03:13 AM
dsk Offline
Never seen that before neighter, found it worth sharing.
dsk
