0 members (), 301 guests, and 15 robots.
Page 3 of 4 1 2 3 4
jdevlin #201020 05/03/11 11:58 PM
Originally Posted by jdevlin
I have to agree with the others.
If you eliminate home owner permits the work will still get done. It just won't get inspected.
I also have to say that the specific issues he points out in his article probably weren't inspected either. I have also seen some stuff like he describes done by so called electricians.
Unfortunately Yes,I agree.
When i have a homeowner Balk- at a permit-
I simply state that Insurance may or may not cover any potential loss- for what ever reason, if the work is not on record. PITA? yes. Do I sleep well? Yes.
People- Contractors as well as home owners think the permitting issue is -- I'm at a loss for words- It just insures that the job is correct,and above board.
In my area- I have never paid more than $100.00 (USD) for a residential permit.
The only hassle has been making sure that Myself or the customer are there to give access.
dougwells #201039 05/05/11 07:11 PM
Originally Posted by dougwells
Anybody want to guess how many hours would be involved in doing an inspection according to this standard . lets say a 3 bedroom house built in the 70;s 2 story 3 bedroom with ceiling fans in bedrooms, and maybe a couple other locations that were diy installed, light fixtures rated for 90c cable only basement finished on weekends with handy andy doing the electrical. decora on aluminum conductors . opening up each opening looking for damaged wiring .
Thanks
This is really part of the problem. I cannot imagine a thorough inspection in less than 1/2 a day but I have seen Whole house inspections done in an hour. To do a real evaluation you need to check every plug with at least a polarity and GFCI tester. Every light fixture in old home shoudl be checked that it is not over heating the wiring and that the temperature requirment of the fixture is met by the wiring. Panel covers off and a really good look. circuiting and verifying the directory. Looking in the attic and crawl spaces. There is a lot ot look at and too much for a 1 or 2 hour call.
dougwells #201041 05/05/11 09:27 PM
I guess if a house is more than 10 years old just a visual look at the plug would tell me it needs replaced. I am always seeing where the piece of plastic is always broken on the face of the plug just under the ground opening.
let alone too loose to retain a plug properly.
dougwells #201042 05/05/11 09:31 PM
Just wondering if anybody has used the tension checker on this link
http://testequipmentandtools.com/acatalog/AC_Receptable_Testers.html
dougwells #201048 05/06/11 12:26 PM
How about this one? This is not an offshore product, but made in the States. Looks like it would give you some good data for a meaningful inspection report.
http://www.tasco-usa.com/inspectorIII.htm
dougwells #201050 05/06/11 01:14 PM
I have one of those, I also think they are making them for amprobe. Inspector 3
dougwells #201055 05/06/11 05:05 PM
they look like a nice tester - what do you think of it Doug? I am considering getting one.
dougwells #201088 05/09/11 07:57 PM
I use that one often in really old houses and doctors offices and treatment rooms.
jay8 #201089 05/09/11 08:00 PM
I like the IDEAL 165 tester for a detailed outlet testing.
dougwells #201099 05/10/11 04:37 PM
TASCO makes ( under label ) a series of Greenlee testers. ( 2007, 2011 )
Their Inspector III is a must have for Service Electricians.
http://www.tasco-usa.com/CMT24S.htm
My favorite is their Circuit Mapper. When you can't possibly shut down breaker after breaker -- it's the cat's pajamas.
Tesla
Page 3 of 4 1 2 3 4
