1 members (triple), 255 guests, and 15 robots.
mamills #183586 01/15/09 02:47 AM
I found this gem at my former place of work. (A Computer Fixing place can't say name)
the receptacle was still in use until I told the maintenance team about the hazard they did not think it was a problem
Oh the bottom right was feeding a 14A air compressor/tank (Used to blow the dust out of computers)
[Linked Image from images.dr3vil.com]
Theres always enough room in the junction box.You just need a bigger hammer
Good eye Randy, I noticed that there was something in that slot to but I never thought of what you mentioned being a possible cause/factor, thanks for the idea. I did suspect a short circuit when I first saw the soot and burn marks that would result from an arc flash.
I have a sense of adventure, I just keep it leashed with common sense.
Wow ComputerWizKid that's some picture, a 14 amp draw on one outlet plus the total amperage draw of everything else that was plugged in and turned on, gee no wonder it fried. Thanks for the post. By the way, if you have any more pictures like this one please send them.
