559
20
am in the process of having 30 furnaces changed out in some rental units and am in a bit of a disagreement with the HVAC guys about the disconnects. While we both agree that one is required, they want to remove the existing SSU's and just install a switch. I would like to leave the SSU's intact, but see the point that an accessible switch serves the purpose. So, I figured I would pose this question to you guys and see what your opinions and/or facts are.
Thanks in advance
"We can do it, you can't help" said my son to the HD guy
Please forgive me, but what do you mean by the acronym "SSU"?
---Ed---
Service/safety/switched shut-off unit?
I wonder if that is another name for disconnect?
SSU/SSY....the terminology escapes me at the moment, but it is the switch used as a disconnect that also incorporates a fuse block.
Are these gas/oil units or electric? If gas/oil, then a standard switch will suffice. The existing disconnects can be reused, but I'd spend the extra couple of bucks and replace it with a new one. If it it an electric/heat pump unit, then that depends upon the manufacturer's name plate ratings as to whether a fused disconnect is required or not.
---Ed---
SSU is a switch and Edison base fuse holder on a handy box cover, manufactured by Bussman. A switch only would work for the furnace. The advantage of the SSU is that a T rated, time delay fuse with a setting close to the rating of the motor can be used to aford better protection than the branch circuit over current device. I used one on my water well, going from a 20 amp circuit breaker to a time delay 8 amp fuse at the pump. It has been in service this way for over 25 years. The fuses cost about $ 3.oo each now but that is still a lot cheaper than a new pump motor.
Posts: 7,382 Likes: 7
OK, now that Alan explained that one; I have not seen one of those in 20 years. Didn't know that Bussmann still made them!
Alan: Is it a true Edison base fuse, or a Fusestat?
