Electricians revenge
1 members (Scott35), 57 guests, and 11 robots.
Originally posted by smokey:
i recently went on a job with a fellow electrician who did not pull an equipment ground through emt that fed some building signs i suggested that we pull a ground to ground our boxes etc. i know that we are not required by code to pull a ground through emt. but i still wanted to pull one just to be safe. i mean what if one of the fittings came loose ? we would lose our ground.i let him talk me out of pulling a groun. what would u guys have done???
I agree, especially in emt, even with compression fittings. I just reviewed a ground fault test I read about in Soares Book on grounding, and in their test they used 2 1/2" rigid made up wrench tite and even after many test the couplings still gave off a shower of sparks, there recommendation was to pull an extra grounding conductor and bond it to the conduit as often as practicable.
I agree with the idea of pulling an equipment grounding conductor. Started my career working in maintenance in a hospital and we were required to pull a green wire, then went to a factory and was made fun of for wanting to pull the green wire. I got the last laugh though, our new electrical engineer want us to pull the green wire in. I've seen far too much conduit(EMT) pulled apart to depend on it.
