0 members (), 128 guests, and 16 robots.
#163036 04/29/07 06:16 PM
I thought I would post this vintage piece of equipment I pulled out of a friends house just before Christmas. when it was removed the fixture DID operate! If you notice on the sticker it was also made right here in this very same city I live in as well.
A.D (Rewired)
Admin #163045 04/29/07 09:03 PM
You can tell it was made for the Niagra Falls area. Who else produced 25 hertz power?
LarryC #163046 04/29/07 09:24 PM
F
Jezzz that is big sucker there i am sure that weight in pretty good in iron wise i dont recall to see the 25 HZ ballast for quite a while whistle
Merci , Marc
Y
There were lots of places with 25Hz power. But driving a fluorescent at that frequency? Ouch! Gives me a headache just to imagine it!
yaktx #163066 04/30/07 06:11 AM
3
Didn't the Pensylvania (spelling?) Railroad use 11000VAC 25Hz for powering those big GG-1 electric locomotives? There was a steel mill that also used 25 Hz supply for the equipment (the name Bethlehem rings a bell-on the eastern side of the U.S.)
32VAC #163081 04/30/07 01:04 PM
Sir Adam Beck in Niagara Falls still has 25 cycle generators. They have several industrial customers on both sides of the border that use it. I think they are trying to phase it out by not renewing the contracts as they expire.
jdevlin #163084 04/30/07 02:25 PM
Here's a great article, titled "The Frequency Changer Era", that discusses 25-cycle power:
http://services3.ieee.org/organizations/pes/public/2003/sep/peshistory.html
Albert #163113 05/01/07 08:37 AM
If you do a search on frequency, 25Hz etc. you'll find several threads where we've discussed the use of 25Hz in the past, and the fact that a few places in the U.S. once used 50Hz (e.g. Los Angeles area up until the 1930s).
One other thing I note about that ballast is the nominal voltage rating: 118V instead of the more usual 117V.
pauluk #163144 05/02/07 07:28 AM
K
I allways thought that in lighting any frequency bellow 50Hz a flicker was noticable by the human eye?
der Großvater
pauluk #163145 05/02/07 08:13 AM
The Canadian volts are not quite as large as the US, so it takes more of them. smile
