504
20
Has anyone tried the fiberglass fish tapes? I was looking at a Greenlee one. It looks like they would push through PVC easier than the steel ones.
Do they splinter? I know my fiberglass fish rods get tiny splinters when they get scraped. Every so often I have to spray them with clear laquer to keep the splinters out of my hands.
I've used the sticks, not the tapes.
I have an Ideal one that is superb. Not sure if it is actually made of fiberglass or plastic, but it slides thru pipe better than the steel ones do.
I have a nice yellow one that's 30 feet long. It's great as long as you are going straight with it. You can't "bend a leg" in it like you can with a steel tape, so I stick with steel ones for routine fishing. The fiberglass one is really nice if you are, say, fishing across a ceiling since it stays flat instead of possibly coiling like steel tapes can do. Remember that fiberglass tapes are a bit stiffer, so working with 1/2 or 3/4" pipe might be tougher since these tapes don't bend into a tight radius. I have had mine for about ten years; no splinters or anything like that. I have lost one of the end eyes, so have to just tape the cable onto it.
---Ed---
I have an Ideal one that I fished out of the dumpster at the supply house. Somebody didn't like it. Had a kink at the end so I just cut a couple of feet off. This is the plastic flexible one and it goes through pipe great. Don't expect to fish walls and ceilings with it though.
For ceilings especially I have the fiberglass rods. They do shed splinters after awhile. I'll have to try the lacquer treatment, else wear gloves.
-Hal
I have a fiberglass one and it is awesome, it is the only way to go when fishing greenfield, I have gotten the fiber snake through a few underground runs where the 1/8" steel wouldn't go. I have had it for about five years and no splinters as of yet. The only complaint was the price, I think it was around $130
yeah, they're good for a lot of things, fishing unknown, abandon conduit runs is nice, *steel hooks on edge of abandon conduit* "Will, go up in the attic (contaning many rat corpses) and find where it got hooked"
they do have a problem with the leaders coming off, I believe Ideal replaces the leaders free of charge for a year or so?
-Will
I have a Ideal that I use at work that I like and feel safer with it. Ed
Posts: 9,931 Likes: 34
Ed is the first guy with a compelling answer. I have to say, sometimes I have a little pucker going on when I am fishing with a steel tape. (and I never see K&T)
I've got a nylon one (forget who it's made by) and I love it for pulling in conduit with energized conductors.
