Electricians revenge
1 members (Scott35), 184 guests, and 13 robots.
3
Trumpys' picture of the PDL vertical power outlet shows a "P" terminal for a pilot light. Was this ever used by anyone to have an external power indication? The "P" terminal was on the load side of the switch & became energised when the switch is in the ON position. Some early (1950s) Clipsal & HPM outlets also had this feature.
A few years ago, a co-worker from Hong Kong sent me a couple 5-amp BS-546 plugs that have a switch AND a neon in the cover.
Never seen one of those, but the same MK BS1363 range I mentioned also had a switched and a switch+neon version.
