0 members (), 709 guests, and 12 robots.
#154446 09/16/05 11:31 PM
Edward Offline OP
Can the dryer exhasut fan exhaust into the crawl space with proper venting? Or it has to vent into open space.
I would say outside to open space because i have been under the house(crawl space) while the dryer was on and it seems to be humid.Which inturn humidity might create mold.
Am i not correct?
Edward
Thanks
Edward
Latest Labor & Material Cost Estimating Guides
Latest Labor and Material Cost Estimating Guides
#154447 09/17/05 10:52 AM
It must vent outside.
Ryan Jackson,
Salt Lake City
#154448 09/17/05 08:30 PM
In the 2000 IRC (which we are still under here) M1501.1 says Clothes Dryer Exhaust: "Dryer exhaust systems shall be independent of all other systems, shall convey the moisture to the outdoors and shall terminate on the outside of the building"
#154449 09/17/05 09:57 PM
Edward Offline OP
Thank you gents.
Thanks
Edward
#154450 11/19/05 05:08 AM
K
kd Offline
In our area, the vent permanently installed must be smooth wall galvanized sheet metal not over, as I remember, 15 feet long. The connection to the dryer must be metallic flexible duct. Improper Dryer venting causes lots of fires.
