1 members (gfretwell),
176
12
Can anyone post a pic of the type of cartridge fuses which were used in the "Main" of these older panels?
Pauluk: [This message has been edited by Hemingray (edited 01-12-2006).]
Cliff
The only thing I can see in the pic is what appears to be a large uninsulated solid conductor on the left side. All the others look pretty small. That's an interesting thing, indeed! I don't see anything like a neutral come in with the feeders at the top either, only a red and a black wire!
Thanks! What would have been the typical rating of these in the era in question? 50 to 100 amps?
for the main fuse? the main was usually 60A max, with the range block having 40A fuses.
Cliff
Love the "Shut both breakers", when of course if you are using that terminology it should be "Open both breakers" as shut would technically leave the circuit energized.
Might want to omit any reference to "open" or "closed" where unqualified persons might be involved. "On" and "off" are less likely to be misunderstood.
Don't you just hate those blue plastic NMC clamps
Thanks.
Mike - After looking closely at the photo I can only guess that the solid conductor you see must be the neutral(??) I'm sure there was a neutral, I think! :-) There was actually very little load on this panel. Well under 60A. I beleive when first checked I was told 18A with the frost free frig running. Gas stove, gas hot water, oil heat, no A/C. Bill
Now that's efficient use of electricity! I wish there were more people using so few electricity - would really help our environment.
